并行计算
浏览:1826 回答:2
***ERROR: The requested number of domains cannot be created due to
          restrictions in domain decomposition. The following limitations may
          be helpful in understanding this behavior:
 1. Contact pair requires that the surface nodes be in the same domain.
             In the case of kinematic contact, elements associated with
             the surface facets must also be in the same domain.
          2. An adaptive mesh domain must be contained within a single
             parallel domain. Nodes on the boundary between an adaptive
             mesh domain and a nonadaptive domain must not be shared
             with other parallel domains.
          3. All the nodes involved in a kinematic constraint must
             be in the same domain and must not be shared with other domains.
          4. Nodes associated with beam elements whose center of mass
             does not coincide with the location of the beam node or which
             use the *BEAM ADDED INERTIA option must be within a single domain.
必亘心
看样子问题是出现在了接触的地方,但是楼主最好能把你的问题介绍的详细一些,比如模型、模型的接触部位,否则,单凭这一错误提示,大家都难以对你的问题进行分析,除非有谁真正遇到了这一问题并解决了。
2016年12月26日
岑波
各位高手这种问题,一般如何解决啊?
2016年12月26日
