input phase completed with 1 fatal errors
浏览:2374 回答:2
@蓝牙
这个error很不解?element ID 0 也没有找到?最后出现了一个input phase completed with 1 fatal errors?
在模拟土弹簧时,我用了只受压得弹簧,在message中出现
spring-damper type set number           1 has a unloading
 modulus reset by ls-dyna to    0.3128E+08
这条命令应该没错吧
