mesh画网格导入fluent中出现警告 这个怎么处理
浏览:4314 回答:1
auto partitioning mesh by Principal Axes
Warning: Partition method "Metis" is not allowed for
autopartitioning for cases with nonconformal
interfaces before the interfaces are defined
and intersected, use "Principal Axes" instead.
You may use the "Metis" partition method
after the case is read in and the interfaces
are intersected.
这个怎么处理
