质量阻尼问题
浏览:1532 回答:2
请教下给位老师们,为什么我在K文件中将空气水写成PART set,然后加*damping_part_mass就出显现超出范围的错误,而给水单独加damp就是对的,不知道什么原因?请老师们帮我看看,以前给part set加就是对的,现在的案列是水下面的壳体里面还填充了部分空气
Gonewithwind
上面就是message文件提示的错误
2016年6月15日
Gonewithwind
 *** Error 20216 (STR+216)
     part # 4 is out-of-range
  1.000E+00 1.000E+00 1.000E+00 1.000E+00 1.000E+00 1.000E+00
     input phase will continue if possible
 contracting memory to     1645160 transformation to move nodes
 expanding   memory to     1683628 ale reference system
 expanding   memory to     1683923 ALE fsi control block
 expanding   memory to     1683927 ALE fsi node and seg list
 expanding   memory to     1695927 ALE fsi seg connectivity
 expanding   memory to     2037723 ALE fsi coupling forces
 expanding   memory to     2065587 void materials
 expanding   memory to     2079439 interfac for file
 contracting memory to     2072497 thermal expansion 0
 expanding   memory to     2072501 mat add cohesive 0
 expanding   memory to     2072505 flexible body 2
 contracting memory to     2072505 implicit joints
 *** Error 20018 (STR+18)
     input phase completed with 1 fatal errors
     please check messag file
2016年6月15日
