浏览:1702 回答:3
@智创仿真 *** OptiStruct defaults set from: install config file: C:\Program Files\Altair\12.0\/hwsolvers/hwsolver.cfg. NOTE # 9199 MSGLMT=BRIEF is active, following messages will be suppressed: 741 742 1935 1052 1305 1436 1437 1051 1931 1932 2010 Use MSGLMT=STRICT (e.g. in config file) to turn back full printing. *** INFORMATION # 743 The total number of rigid elements, whose rotational dependent d.o.f. are removed because there is no need to constrain those d.o.f., is 36 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 1 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 2 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 3 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 4 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 5 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 6 ************************************************************************ OPTIMIZATION FILE AND PARAMETER INFORMATION : --------------------------------------------- FEM model file : E:/assemble five 119(5).fem Output files prefix : E:/assemble five 119(5) Model read from files: E:/assemble five 119(5).fem ************************************************************************ ************************************************************************ FINITE ELEMENT MODEL DATA INFORMATION : --------------------------------------- Total # of Grids (Structural) : 108699 Total # of Elements : 116522 Total # of Rigid Elements : 2354 Total # of Rigid Element Constraints : 14124 Total # of Degrees of Freedom : 642531 Total # of Non-zero Stiffness Terms : 17583135 Element Type Information ------------------------ CTETRA Elements : 8545 CPYRA Elements : 1381 CQUAD4 Elements : 105550 CTRIA3 Elements : 1046 Load and Boundary Information ----------------------------- FORCE Sets : 1 SPC Sets : 1 Material and Property Information --------------------------------- PSOLID Cards : 1 PSHELL Cards : 1 MAT1 Cards : 1 ************************************************************************ ************************************************************************ ***** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN ***** Current Memory (RAM) : 204 MB Estimated Minimum Memory (RAM) for the check run : 207 MB ************************************************************************ This error occurs in module "prpdrv". ************************************************************************ RESOURCE USAGE INFORMATION -------------------------- MAXIMUM MEMORY USED 204 MB MAXIMUM DISK SPACE USED 1 MB ************************************************************************ ************************************************************************ COMPUTE TIME INFORMATION ------------------------ EXECUTION STARTED Sun May 22 22:45:41 2016 EXECUTION COMPLETED Sun May 22 22:45:44 2016 ELAPSED TIME 00:00:02 CPU TIME 00:00:02 ************************************************************************ *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED. ***** END OF REPORT ***** For Useful OptiStruct Tips and Tricks, go to the URL: http://www.altairhyperworks.com/tips.aspx ************************************************************************ There were 6 error messages during input processing. The first message is repeated below: *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 1 **************************************************** 这个如何解决啊
陈关宝
@智创仿真 ,哈哈哈 你真幽默 另PS一句:错误不是告诉你了吗?GRID ID = 248928 shift+F5,里面by id查找
2016年5月23日
智创仿真
你可真直接啊,把所有的信息都贴出来了。rigid单元上约束有问题。
2016年5月23日
