odb文件打开出现“ensure that the file was copied using the binary mode
浏览:2291 回答:1
| 请问从Linux系统计算得到的odb文件,拷贝到Windows系统后,打开报错: ***ERROR: The Abaqus database file is corrupt. If this file was transferred from another machine using FTP or equivalent, ensure that the file was copied using the binary mode instead of ASCII mode。 怎么解决? |
同问,楼主解决了没有?
我也出现了这个问题,如果是小模型,我就重新再计算一遍,重新传输。
