abaqus热辐射仿真提交job如何解决下面的error?
浏览:1996
ERROR: A CAVITY INT-1 WITH 149668 FACETS REQUIRES MORE THAN 16GB OF MEMORY.
           CONSIDER REDUCING THE SIZE OF THE CAVITY OR PERFORMING THE ANALYSIS
           ON MORE DOMAINS.
