dyna中设置渗透率的关键字MAT_ADD_PERMEABILITY如何设置渗透率与体积比的关系?
浏览:2243
EQ.1: PERM is a load curve ID giving permeability (y-axis) as a function of the volume ratio of current volume to volume in the stress-free state (x-axis)
