求助,abaqus模型不收敛,矩阵有大量负特征值什么原因?
浏览:2984 回答:5
The system matrix has 24249 negative eigenvalues.
The system matrix has 94131 negative eigenvalues.
Excessive distortion at a total of 41177 integration points in solid (continuum) elements
The system matrix has 101 negative eigenvalues.
The system matrix has 40626 negative eigenvalues.
Excessive distortion at a total of 34586 integration points in solid (continuum) elements
FORCE equilibrium accepted using the alternate tolerance.
SnowWave02
