请问GETVRM中ARRAY返回值一直为0是什么原因呢? 12
浏览:2802
代码如下:
        CALL GETVRM('THE',ARRAY,JARRAY,FLGRAY,JRCD,JMAC,JMATYP,
     1 MATLAYO,LACCFLA)
      STATEV(1)= ARRAY(1)
C
C    Reading instantaneous elastic x axial strain
C    Storing the thermal strain in state variable
C    NOTE: ARRAY(1)--X AXIAL
C          ARRAY(2)--Y AXIAL
C          ARRAY(3)--Z AXIAL
C
        CALL GETVRM('EE',ARRAY,JARRAY,FLGRAY,JRCD,JMAC,JMATYP,
     1 MATLAYO,LACCFLG)
          EPS = ARRAY(1)
          FIELD(1) = EPS
          STATEV(2) = FIELD(1)
      IF (LGT(CMNAME,"MAT-SLAB")) THEN
          STATEV(22)= ARRAY(1)
      END IF
C
      CALL GETVRM('SDV',ARRAY,JARRAY,FLGRAY,JRCD,JMAC,JMATYP,
     1     MATLAYO,LACCFLA)
      STATEV(3)= ARRAY(3)
      STATEV(4)= ARRAY(4)
