ABAQUS报错怎么解决?
浏览:3010 回答:1
ABAQUS提交作业时,提示:DEGREE OF FREEDOM 11 AND AT LEAST ONE OF DEGREES OF FREEDOM 1 THRU 6 MUST BE ACTIVE IN THE MODEL FOR *DYNAMIC TEMP-DISP. CHECK THE PROCEDURE AND ELEMENT TYPES USED IN THIS MODEL.应该怎么解决?
