abaqus温度位移耦合后接振动分析报错?
浏览:3049 回答:5
Three factorizations in a row failed. Check the model. It is possible that the model contains the kinematic coupling definition set up in a way that a degree of freedom has neither mass nor stiffness。
温度位移耦合和振动分析单独分开来是没问题的,但是把他们衔接上就会出现问题,每次在完成温度位移耦合分析后就直接报错了,进行不了振动分析,显示Three factorizations in a row failed. Check the model. It is possible that the model contains the kinematic coupling definition set up in a way that a degree of freedom has neither mass nor stiffness?
汴京抓鱼人
设置的条件少些,看看具体哪块问题不能满足你的分析要求
2024年12月29日
