大佬们,请问这些报错怎么解决?
浏览:3063 回答:1
The reference node 579 instance plan-1 on the *coupling option is not defined.
A boundary condition has been specified on node set assembly__pickedset506 but this node set is not active in the model
Node set assembly__pickedset505 has not been defined
A concentrated load has been specified on node set assembly__pickedset505. This node set is not active in the model
Node set assembly__pickedset506 has not been defined
Analysis Input File Processor exited with an error - Please see the Job-2.dat file for possible error messages if the file exists.
是不是在做显隐式数据传递的时候出的问题
