扫掠网格划分出现如下字符如何解决?
浏览:2243
APDL网格划分时出现4 of the specified volumes could not be swept(see above)because a source and target areacould not be determined automatically.Try theVSWEEP command again for each of these volumesand specify a source and target area.怎么解决哪?
扫掠网格划分出现如下字符如何解决?的图1
