烦请看一下报错问题 30
浏览:3794 回答:2
The *tie pair (assembly_surf-26-ouhemian,assembly_surf-19) is also used as *contact pair. Remove this *contact pair. The same pair of surfaces cannot be specified more than once for *tie and *contact pair. Once a pair of surfaces is used for *tie, it cannot be used again for *contact pair and vice versa.
