200
浏览:3753 回答:1
 MAX. PENETRATION ERROR 34.4485E-09  AT NODE 270821 OF CONTACT PAIR (S2,S1)
   MAX. CONTACT FORCE ERROR -18.3432E-09  AT NODE 270738 OF CONTACT PAIR (S2,S1)
          THE CONTACT CONSTRAINT ERRORS ARE WITHIN THE TOLERANCES.
 AVERAGE FORCE                      2.817E-02   TIME AVG. FORCE       1.362E-02
 LARGEST RESIDUAL FORCE            -2.080E-04   AT NODE     152758   DOF  1
 LARGEST INCREMENT OF DISP.        -1.973E-03   AT NODE     260826   DOF  3
 LARGEST CORRECTION TO DISP.        9.120E-04   AT NODE     152764   DOF  1
          FORCE     EQUILIBRIUM NOT ACHIEVED WITHIN TOLERANCE.
 AVERAGE MOMENT                     0.166       TIME AVG. MOMENT      7.840E-02
 LARGEST RESIDUAL MOMENT           -5.474E-04   AT NODE     205082   DOF  5
 LARGEST INCREMENT OF ROTATION     -1.722E-03   AT NODE     204713   DOF  6
 LARGEST CORRECTION TO ROTATION    -3.746E-03   AT NODE     204716   DOF  6
          MOMENT    EQUILIBRIUM NOT ACHIEVED WITHIN TOLERANCE.
报这个错误怎么解决
用户_58714
同学你回了的话教教我 咱俩可以平摊钱
2024年12月3日
