Hyperworks进行optistruct计算后,出现柔度值为负的现象,这应该怎么解决?
浏览:2663 回答:2
*** ERROR # 312 ***
  In static load case 1
  the compliance is negative or large -1229.72.
  Optimization/buckling analysis cannot be performed.
  due to possible rigid body mode.
  FEASIBLE DESIGN (ALL CONSTRAINTS SATISFIED).
  *** SOME ERRORS WERE REPORTED DURING THE RUN,
  *** PLEASE VERIFY RESULTS AS THEY MAY BE INVALID.
这是哪里的问题?
TechmanLXS
约束不充分,出现很大的位移移动了
2024年1月8日
