浏览:2229 回答:1
 Beginning to read structured input file ***
 *** Error 20001 (STR+1)
     input error found in structured input
     reading 1st control card
     line number 2 contains improperly formatted data
 **************************************** line# 2
 This problem may be solved by using long=s option.
        ?      詭-            骭s|?  =?v
 E r r o r   t e r m i n a t i o n                             12/14/23 14:53:48
 Memory required to complete solution   :        0
 Additional dynamically allocated memory:      600
                                   Total:      600
请问下各位大佬,这个怎么解决啊,怎么一运行就报错了。谢谢
阿辉想要糖
你好请问这个解决了吗
2025年6月11日
