SPH in bucket sort of particles time?
浏览:3492 回答:1
在做伪二维sph爆炸模拟时,求解出现警告后就卡住了,不知道哪里出现了什么问题,求大佬指点!
Beginning of keyword reader                                   11/06/23 23:20:58
 Memory required to process keyword     :    1172409
 Additional dynamic memory required     :    4913553
 input of data is completed
 initial kinetic energy = 0.00000000E+00
 The LS-DYNA time step size should not exceed     8.278E+00
 to avoid contact instabilities.  If the step size is
 bigger then scale the penalty of the offending surface.
 Memory required to begin solution      :    1432K
 Additional dynamically allocated memory:      63M
                                   Total:      64M
 initialization completed
     Message 40538 (SOL+538) exceeds 50 times
     Further printing will be suppressed from screen only
 Summary of warning messages for interface #   = 1
   number of warning messages                  = 62320
       1 t 0.0000E+00 dt 2.40E+00 flush i/o buffers            11/06/23 23:21:07
       1 t 0.0000E+00 dt 2.40E+00 write d3plot file            11/06/23 23:21:07
 cpu time per zone cycle............     25777 nanoseconds
 average cpu time per zone cycle....     26949 nanoseconds
 average clock time per zone cycle..     27467 nanoseconds
 estimated total cpu time                  =       6107 sec (       1 hrs 41 mins)
 estimated cpu time to complete      =      6077 sec (       1 hrs 41 mins)
 estimated total clock time                =      6224 sec (       1 hrs 43 mins)
 estimated clock time to complete    =      6194 sec (       1 hrs 43 mins)
 termination time                  = 7.000E+03
 *** Warning 41123 (SOL+1123)
     SPH in bucket sort of particles time 3.5568E+01
     Increasing memory for buckets
     Old : 388492 New : 776984
     SPH in bucket sort of particles time 3.5580E+01
     Old : 1282024 New : 2564048
 dt of cycle      18 is controlled by sph           148820
 time...........................   3.55802E+01
 time step......................   6.75545E-04
 kinetic energy.................   2.30863E+13
 internal energy................   9.49057E+08
 spring and damper energy.......   1.00000E-20
 hourglass energy ..............   1.14217E-10
 system damping energy..........   0.00000E+00
 sliding interface energy.......   2.00462E-09
 external work..................   0.00000E+00
 eroded kinetic energy..........   0.00000E+00
 eroded internal energy.........   0.00000E+00
 eroded hourglass energy........   0.00000E+00
 total energy...................   2.30872E+13
 total energy / initial energy..   4.44942E+11
 energy ratio w/o eroded energy.   4.44942E+11
 global x velocity..............   1.02365E-01
 global y velocity..............   4.09671E-04
 global z velocity..............  -6.98035E-02
 cpu time per zone cycle............   1933338 nanoseconds
 average cpu time per zone cycle....    253482 nanoseconds
 average clock time per zone cycle..    253506 nanoseconds
 estimated total cpu time                = 202750688 sec (   56319 hrs 38 mins)
 estimated cpu time to complete    = 202750327 sec (   56319 hrs 32 mins)
 estimated total clock time              = 202770161 sec (   56325 hrs  2 mins)
 estimated clock time to complete  = 202769800 sec (   56324 hrs 56 mins)
SPH in bucket sort of particles time?的图1
