abaqus筒仓静态侧压力分析提交作业出现错误?
浏览:2390 回答:1
abaus 建一个筒仓时提交作业出现
TWO BOUNDARY CONDITIONS WITH CONFLICTING DISPLACEMENTS HAVE BEEN IDENTIFIED FOR NODE 56 INSTANCE SILO-1 DOF 1. THIS SITUATION MAY ALSO OCCUR WHEN BOUNDARY CONDITIONS HAVE BEEN DEFINED FOR A NODE SET CONTAINING THIS NODE AND LATER RE-DEFINED USING THE NODE LABE INSTEAD. IF THIS IS THE CASE, PLEASE MAKE THE DEFINITIONS CONSISTENT BY USING EITHER THE NODE SET OR NODE LABEL.
