Abaqus There is zero PR ?
浏览:2677
请问一下,在使用abaqus进行模拟时,warnings这部分出现了There is zero PR. FLUX everywhere in the model based on the default criterion. please check the value of the average PR. FLUX during the current iteration to verify that the PR. FLUX is small enough to be treated as zero. if not, please use the solution controls to reset the criterion for zero PR. FLUX. 这是是那么原因造成的,该怎么解决呢
