用inp文件定义局部坐标各向异性报错怎么解决? 110
浏览:3263
我定义了一个8单元结构,在inp文件里想通过节点建立局部坐标系来赋予各向异性材料方向,但是导入之后会有“ValueError: operands could not be broadcast together with shapes (0,) (3,)  This occurred while creating part level orientation ORI-1. The region in question will not be imported. ”的提示报错,提示我创建局部坐标系出错,下面是我的inp文件:
*Heading
** Job name: Job-1 Model name: Model-1
** Generated by: Abaqus/CAE 2020
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Part-1
*Node
      1, -0.00999999978, -0.00999999978, 0.0199999996
      2, -0.00999999978,           0., 0.0199999996
      3, -0.00999999978, 0.00999999978, 0.0199999996
      4, -0.00999999978, -0.00999999978, 0.00999999978
      5, -0.00999999978,           0., 0.00999999978
      6, -0.00999999978, 0.00999999978, 0.00999999978
      7, -0.00999999978, -0.00999999978,           0.
      8, -0.00999999978,           0.,           0.
      9, -0.00999999978, 0.00999999978,           0.
     10,           0., -0.00999999978, 0.0199999996
     11,           0.,           0., 0.0199999996
     12,           0., 0.00999999978, 0.0199999996
     13,           0., -0.00999999978, 0.00999999978
     14,           0.,           0., 0.00999999978
     15,           0., 0.00999999978, 0.00999999978
     16,           0., -0.00999999978,           0.
     17,           0.,           0.,           0.
     18,           0., 0.00999999978,           0.
     19, 0.00999999978, -0.00999999978, 0.0199999996
     20, 0.00999999978,           0., 0.0199999996
     21, 0.00999999978, 0.00999999978, 0.0199999996
     22, 0.00999999978, -0.00999999978, 0.00999999978
     23, 0.00999999978,           0., 0.00999999978
     24, 0.00999999978, 0.00999999978, 0.00999999978
     25, 0.00999999978, -0.00999999978,           0.
     26, 0.00999999978,           0.,           0.
     27, 0.00999999978, 0.00999999978,           0.
*Element, type=C3D8R
1, 10, 11, 14, 13,  1,  2,  5,  4
2, 11, 12, 15, 14,  2,  3,  6,  5
3, 13, 14, 17, 16,  4,  5,  8,  7
4, 14, 15, 18, 17,  5,  6,  9,  8
5, 19, 20, 23, 22, 10, 11, 14, 13
6, 20, 21, 24, 23, 11, 12, 15, 14
7, 22, 23, 26, 25, 13, 14, 17, 16
8, 23, 24, 27, 26, 14, 15, 18, 17
*Nset, nset=Set-1, generate
  1,  27,   1
*Elset, elset=Set-1, generate
 1,  8,  1
*Orientation, name=Ori-1, system=Z RECTANGULAR
1,13,4
1,0
** Region: (Section-1:Picked), (Material Orientation:element-1)
*Elset, elset=_I1
1,
** Section: Section-1
*Solid Section, elset=_I1, orientation=Ori-1, material=Material-1
*Orientation, name=Ori-2, system=Z RECTANGULAR
2,14,5
1,0
** Region: (Section-1:Picked), (Material Orientation:element-2)
*Elset, elset=_I2
2,
*Solid Section, elset=_I2, orientation=Ori-2, material=Material-1
*Orientation, name=Ori-3, system=Z RECTANGULAR
4,16,7
1,0
*Elset, elset=_I3
3,
*Solid Section, elset=_I3, orientation=Ori-3, material=Material-1
*Orientation, name=Ori-4, system=Z RECTANGULAR
5,17,8
1,0
*Elset, elset=_I4
4,
*Solid Section, elset=_I4, orientation=Ori-4, material=Material-1
*Orientation, name=Ori-5, system=Z RECTANGULAR
10,22,13
1,0
*Elset, elset=_I5
5,
*Solid Section, elset=_I5, orientation=Ori-5, material=Material-1
*Orientation, name=Ori-6, system=Z RECTANGULAR
11,23,14
1,0
*Elset, elset=_I6
6,
*Solid Section, elset=_I6, orientation=Ori-6, material=Material-1
*Orientation, name=Ori-7, system=Z RECTANGULAR
13,25,16
1,0
*Elset, elset=_I7
7,
*Solid Section, elset=_I7, orientation=Ori-7, material=Material-1
*Orientation, name=Ori-8, system=Z RECTANGULAR
14,26,17
1,0
*Elset, elset=_I8
8,
*Solid Section, elset=_I8, orientation=Ori-8, material=Material-1
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*End Instance
*Nset, nset=Set-1, instance=Part-1-1
  1,  2,  3, 10, 11, 12, 19, 20, 21
*Elset, elset=Set-1, instance=Part-1-1
 1, 2, 5, 6
*Elset, elset=_Surf-1_S4, internal, instance=Part-1-1, generate
 2,  8,  2
*Surface, type=ELEMENT, name=Surf-1
_Surf-1_S4, S4
*End Assembly
** MATERIALS
*Material, name=Material-1
*Elastic, type=ORTHOTROPIC
 1.37485e+08, 7.94493e+07, 1.37485e+08, 4.44715e+07, 4.44715e+07, 6.29233e+08,       1e+08,       1e+08
     3.2e+07,
** STEP: Step-1
*Step, name=Step-1, nlgeom=NO
*Static
1., 1., 1e-05, 1.
** BOUNDARY CONDITIONS
** Name: BC-1 Type: 对称/反对称/完全固定
*Boundary
Set-1, ENCASTRE
** LOADS
** Name: Load-1   Type: Pressure
*Dsload
Surf-1, P, 200000.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
请问我的错误在哪里呢
