更新后,打开低版本的模型,提交后报错?
浏览:3100 回答:1
The database is from a previous release of Abaqus.
Run abaqus -upgrade -job <newFileName> -odb <oldOdbFileName> to upgrade it.
Job sanwei-A4-OK--2021: Analysis Input File Processor aborted due to errors.
Error in job sanwei-A4-OK--2021: Analysis Input File Processor exited with an error.
Job sanwei-A4-OK--2021 aborted due to errors.
SnowWave02
按它提示update一下呢?
2022年10月25日
