Abaqus中的viscoelastic粘弹性问题? 10
浏览:3970 回答:2
各位大佬们,材料属性设置了viscoelastic粘弹性,但是在job里warnings出现了:Viscoelastic material properties are defined in the model. The material response in a static analysis will be based on the instantaneous elastic material properties. 请问有什么方法解决?
九千CAE
