ABAQUS初始状态导入变形网格和材料状态时不收敛怎么办? 100
浏览:3087 回答:4
导入前为原始分析,导入后为后续分析。当原始分析结束后结构有较大局部变形,初始状态导入后,后续分析不收敛。主要警告:The strain increment is so large that the program will not attempt the plasticity calculation at 16 points;The strain increment has exceeded fifty times the strain to cause first yield at 115 points;The strain increment is so large that the program will not attempt the plasticity calculation at 27 points 报错信息:Too many attempts made for this increment
