大家帮忙看看这个错误是什么意思
浏览:5092 回答:2
 *** OptiStruct defaults set from:
   install config file: D:\CX\Hyper\/hwsolvers/optistruct.cfg.
 NOTE # 9199
 MSGLMT=STRICT is active, all messages will be printed.
 You can suppress some less important warning messages by use of
  MSGLMT=BRIEF or UNREF (in config file or in the input data).
 NOTE # 1929
 Created RAM scratch area: total size 200 MB.
 *** ERROR 14: Missing      MAT #    1 referenced by  PSHELL # 1.
 *** Errors with missing, incorrect or duplicate IDs found 3 times.
   IN ADDITION    200 MB RAMDISK AREA WAS ALLOCATED IN MEMORY
 MAXIMUM DISK SPACE USED                                     1 MB
COMPUTE TIME INFORMATION
 EXECUTION STARTED                         Sat Jul 31 14:50:58 2021
 EXECUTION COMPLETED                       Sat Jul 31 14:50:58 2021
 ELAPSED TIME                                         00:00:00
 CPU TIME                                             00:00:00
 *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
 For Useful OptiStruct Tips and Tricks, go to the URL:
 http://www.altairhyperworks.com/tips.aspx
 There were 3 error messages during input processing.
  The first message is repeated below:
北鲲
缺材料psh
2021年8月6日
北斗七星仿真工作室
材料
2021年8月5日
