The memory allocated to process constraint is not adequate. Set the environment variable aba_scale_std_contact_connectivity.只要设置接触就出现这个问题!该怎么解决呢? 10
浏览:3235 回答:1
老师们我在abaqus中遇到了这样的报错,The memory allocated to process constraint is not adequate. Set the environment variable aba_scale_std_contact_connectivity to a value larger than 1.0 and rerun the analysis.只要设置接触就出现这个问题!该怎么解决呢?
