abaqus子程序关联aba2020+VS2019+IntelParallelStudio2020? 60
浏览:3088 回答:7
ABAQUS子程序关联的时候碰到了这个问题,希望能有大神指导解决!!!!
下面是验证时候的log文件,pass部分我已经删除
Abaqus/Standard with user subroutines
         ...INFORMATION
            Abaqus/Standard and CAA are required to run this
            test.  Ensure installation component Abaqus/Standard
            is installed, and CAA media has been run.
         Continuing...
Abaqus/Explicit with user subroutines (single precision)
         ...INFORMATION
            Abaqus/Explicit and CAA are required to run this
            test.  Ensure installation component Abaqus/Explicit
         Continuing...
Abaqus/Explicit with user subroutines (double precision)
         ...INFORMATION
         Continuing...
Abaqus make utility with Fortran
         ...INFORMATION
            Abaqus/Standard or Abaqus/Explicit must be installed
            to run this test.  Also Abaqus ODB API Services must
            be installed.  When all these components are
            installed, CAA media must be run.
         Continuing...
Abaqus make utility with C++
         ...INFORMATION
         Continuing...
Abaqus make utility with object code
         ...INFORMATION
         Continuing...
降维打击
你具体是怎么关联的
2021年3月21日
已采纳 评论 2 点赞 2
文泉
问题已解决
2021年3月22日
评论 2 点赞 1
用户_86580
请问怎么解决的呀,我也遇到这个问题了
2025年5月9日
