想问一下,ABAQUS出现这样的错误应该怎么修改? 20
浏览:2065
Thermal interaction is involving the analytical rigid surface ASSEMBLY_GUN-UP_GUN-UP-WAI, but this surface has not been defined as an isothermal rigid body.
