ABAQUS仿真老是不收敛
浏览:2369
检查了好几遍接触和分析步设置结果老是显示
Too many increments needed to complete the step
The analysis has been terminated due to previous errors. All output requests have been written for the last converged increment.
Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.
最后结果下板材明显变形过大
求指教
ABAQUS仿真老是不收敛的图1
