ABAQUS中点面tie出现的错误?
浏览:1782
想请教各位大佬一个问题,就是我墙壁和梁用点面(tie绑定),然后给墙壁加顶推力,结果加到一定数值,出现这个错误:The plasticity/creep/connector friction algorithm did not converge at 1 points 有好几个点,这样是表示破坏吗??
