提交abaqus 的vumat时使用连续壳单元计算,总是出现如下的错误,求解答,谢谢?
浏览:2795 回答:3
Bad Material definition in element number 83011 instance PART-1-1 zero or negative initial dilatational modulus caused by bad material data. Please check your material input and any initial conditions if necessary.
北望逸尘
