ABAQUS壳-梁单元,梁作为壳的加强如何建模?
浏览:2497 回答:3
想建立一种带有加强肋/翼缘(不知这样说是否准确)的隧道管片进行受力分析,建模时直接在壳单元上创建纵梁的形式,在平面上试验过是可以实现的,但是在曲面的壳上建模时总是有如下的报错,请问各位大神有没有遇到过这样的问题?应该如何解决?或者想要进行这样的分析有没有其他的方法可以操作?
警告信息:For 600 beam elements either the average curvature about the local 1-direction differs by more than 0.1 degrees per unit length as compared to the default curvature or the approximate integrated curvature for the entire beam differs by more than 5 degrees as compared to the approximate integrated default curvature. This may be due to a user-specified normal or due to the nodal averaging routine used by Abaqus. This difference may cause unexpected behavior of the beam and you may want to verify that the beam normals are correct for your problem. The elements have been identified in element set WarnBeamCurvature1.
北望逸尘
