我这边的仿真出现下面的问题,请问哪位老师帮忙看看是什么原因? 20
浏览:2123 回答:3
74 nodes are used more than once as a slave node in *TIE keyword. These constraints are not removed either due to the presence of *CONSTRAINT CONTROLS,NO CHANGES keyword or because removing the constraints might affect the model. The nodes have been identified in node set ErrNodeOverconTieSlave.
tie连接定义有问题, 你在后处理中找到提示的节点集合,仔细检查节点定义是否出现了问题
